Sign in
Sign out
on 23-04-2020 18:22
Anyone else, have to bang the volume control right up.
23-04-2020 18:23 - edited 23-04-2020 18:24
What is you audio setting set to on the V6? 'Dolby Digital' or 'Dolby Digital to PCM'?
And what audio system are you using?
on 23-04-2020 18:29
Well it was on alternate audio, tried the other 2, no difference. Just using the dolby atmos thats in the set, 65" lg oled.
on 01-05-2020 07:28
on 01-05-2020 08:59
Hi roddydogs
I am sorry to hear about the issues which you are having with the on demand service. Is this the same across all devices? -Chris
on 01-05-2020 09:07
Only use 1
on 01-05-2020 09:38
Can you confirm what the volume control (Audio) settings are set at? Are these set to variable? ^Chris
