Alan-from-Hemel
  • 9
Message 1 of 5
Low sound on BT ultimate football
Why is the sound low on BT Ultimate football? I normally watch HD games at sound level 16 on my TV but I have to turn it up to 40 when it's on BT ultimate. Any ideas? Thanks.
Kain_W
  • 3.74K
  • 102
  • 265
Message 2 of 5
Re: Low sound on BT ultimate football
Apologies for any issues faced Alan-from-Hemel.
Welcome back to the community.
Can I ask are you facing any issues on any other channels?
Kain
Alan-from-Hemel
  • 9
Message 3 of 5
This is the only channel that gives me the problem - channel 531 on Virgin V6.
Alan.
Carley_S
  • 3.11K
  • 163
  • 263
Message 4 of 5
Thank you for confirming this @Alan-from-Hemel.
Can you try to see if these steps help at all? On your set top box go to > Help & Settings > Settings > Audio > Dolby digital and select Dolby digital to PCM.
Let me know if this resolves your issue.
Carley - Forum Team
Alan-from-Hemel
  • 9
Message 5 of 5
Thanks. I changed to PCM and the sound returned to my normal level, solving my problem. This creates a different situation - it made no difference to the rugby yesterday but improves my football commentary listening. Also, if I apply PCM to a HD football match, it has the effect of raising the crowd noise level and leaving the commentary level the same, with the result that the crowd noise drowns out the commentary and I have to remove PCM. Maybe this is food for thought for the audio engineers at the matches.
