Hi both,
Thanks for chipping in, and tryign to help 🙂
@Zoie
The only sync issues I have are when viewing content from the V6 box, that is sent to my TV via the HDMI1 socket, then down to the soundbar via HDMI3 (the eARC socket on my TV). Content that is 'native' to the TV (either over the air or via one of the TV's apps) is in sync.
Content viewed via one of the V6's apps (e.g. iPlayer, Sky Cinema) seems to be OK, but I guess this is a function of how it is being sent and decoded.
I realise that VM can't always guarantee third-party compatibility, but Samsung are a pretty big manufacturer of TVs and soundbars, not some niche company with questionable production/quality standards, and looking at other forum posts it seems that this issue has been ongoing for some time.
@Roger
I'll give that method a go, and see what happens, although as HDMI 3 is the eARC socket on my TV, I guess I'll lose the ability to output sound from the TV, when viewing content directly? it's also a bit annoying to lose the extra functionality wrt using a single remote control etc., but I guess I'll find some workarounds.
I read about eARC reportedly solving the lip sync problems, so will look into that a bit more, and see if there is anything I might be missing.
As you suggest, I'm keen to avoid the PCM 'dumbing down' solution if I can avoid it, but in reality what content on the V6 box would really be affected by this? I don't care about news, quizzes, soaps etc. being in 'plain' stereo, and I watch just about everything else on demand/catch-up, which seems OK, so it may be the case that I use PCM by default and change when I want to watch something with decent sound on demand. Not ideal, but not too much hassle either.
@Both
I have been offered a software upgrade to V360 - might this solve the problem? (although I have seen the extensive thread on syncing issues with 360 too, as AIUI it's a one-way transition, with no going back).
Thanks again both - any other thoughts are appreciated. (I'll also contact Richer Sounds and see if they have any advice - maybe a threat to return the TV and/or soundbar might focus their minds a bit....)
Chris
