on 10-08-2023 17:47
We are experiencing intermittent picture and sound breaking up on sky sports.
Today on channel 515 (Golf) which was also showing in 511 (Main Sport) which was fine.
The other day it occurred on other Sky Sports channels. Other, none Sky Sports channels, were not affected.
Is anyone else experiencing this?
Nick
Answered! Go to Answer
on 10-08-2023 22:50
Pixellated pictures on live TV are often the sign of a signal fault. If you've rebooted your box once, then there's likely a fault somewhere, so this will need VM to intervene. There's a good chance some non-Sky Sports channels are affected, but you may not have identified them - each SD channel shares a TX with approximately 12 others, but these are intentionally spread across genres.
First check the automated faults line for any existing issues in your area that could be the cause: 0800 5610061. If nothing's reported, assume VM don't know about your fault and ideally you'll need to call them.
150 from a VM phone, 0345 4541111 from any other phone - choose the options for "I have a fault with my TV service". Alternatively you can wait on here for staff to respond, which may take a day or so.
on 10-08-2023 22:50
on 10-08-2023 23:01
HI,
Thank you for your input. The box has been rebooted twice, making no difference, also, the online VM Status showing no problems.
I was hoping to avoid the 150 call.
Will try the 0800 number / call VM tomorrow.
Nick
on 10-08-2023 23:05
The online status is better for widespread, regional or national faults. Signal issues tend to be more localised and often down to postcode level.
VM staff often respond on here, but expect a 1-2day response time.
on 11-08-2023 12:05
Hi NickBatch,
A warm welcome and thanks for posting on our community forums. We're sorry to hear that you're experiencing intermittent picture and sound on your Sky sports channel.
Can we ask if this is a HD channel or SD?
Have you noticed this issue on any other channel other than Sky sports?
Can we ask if you able to check all the cables are finger tight and secure and that your HDMI cable secure.
Upon checking from our end, it is showing your equipment as offline, so we're unable to carry out further diagnostics.
Do you currently have your STB in standby? If not, can we ask you to reboot your box and let us know when you have done this.
Kind regards Jodi.
on 12-08-2023 00:14
Turned out to be a loose connection on the coax connection at the wall. Unsure how it worked loose.
Don't know why VM thought the kit was offline at it's never off and was, successfully recording today.
VM, please check you are trying to connect to the correct STB. I only have the Tivo V6 connected now.
Thanks to Japitts and Jodi for responding. Nick
