Just joined
Interference
hi
im getting picture break up on both live and recorded programs I have 2 box’s in 2 different rooms and am only experiencing problems with the older box so I know that the incoming signal is good.
ive read previous posts and therefore have checked that all the cables are fully inserted.
any advice would be appreciated
sorry for the underlined post I’m not sure how this happened
  • 31.3K
  • 1.62K
  • 5.47K
Re: Interference
how do you know the incoming signal is good? you can have different signals on each point.
