IR Blaster won't let me control Tivo V6 box with Sonia Bravia remote
 I have just purchased a new Sony Bravia TV and connected the IR Blaster cable which in theory means I can operate my TIVO V6 box from the TV remote.
I went through the set up process to try and connect it but no luck.    In the set up it asks me to run a test by trying the Program Up button but this doesn't work, I press 'try again with different' code but still nothing.
Can anyone help me?    I am assuming my Tivo V6 has IR blaster compatibility?
Is there some setting I need to change on the Tivo and if so please could you give step by stap instructions on how to do this please
Thank you
  • 10.93K
  • 727
  • 1.51K
Re: IR Blaster won't let me control Tivo V6 box with Sonia Bravia remote
The Tivo doesnt need set up for IR blasters, I would seek help from Sony
  • 14.81K
  • 1.61K
  • 3.34K
V6 remotes run on RF not IR, so that the boxes can be hidden away in cupboards/cabinets etc & will still operate normally.
Click to learn more about VIP
Use Kudos to say thanks
So I take it that means they V6 box can't be paired with my Sony Bravia remote via IR?
Just with a sound bar too I have to turn on/off TV, sound bar and V6 box every time I want to watch TV (3 different remotes)
