Nicci2017
Message 1 of 12
How to work my virgin remote on my hisense tv
I have a 65inch hisense tv and the volume doesnt work with my virgin remote.
please help
  • 4.88K
  • 339
  • 829
Roger_Gooner
Superstar
Message 2 of 12
Re: How to work my virgin remote on my hisense tv
https://community.virginmedia.com/t5/Help/Set-up-Your-Virgin-Remote-Control-to-operate-the-Volume-an...
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
Nicci2017
Message 3 of 12
Still has not worked.
  • 945
  • 79
  • 132
michaeldavis
Well-informed
Message 4 of 12
Getting your V6 remote to do volume control and standby on your TV is not easy to get working correctly if you follow the documentation that is supplied, but all is not lost, the following does work:
Programming your remote using a device code
If you’ve been unable to program your remote by searching for the correct code, you can also program the correct code into your remote from the device code list.
1. Make sure your TV and your Virgin TV V6 box are switched on
2. Find your make of TV and the 4 digit code(s) that match it here. If there‘s more than one code for your TV make, try the codes in the order listed, its a good ides to make sure that this open in a new tab/window https://assets.virginmedia.com/help/assets/documents/vm-tivo-code-list2012.pdf
3. Press and hold down Clear and TV at the same time, until the light on the top of the remote flashes green twice
4. Enter the four digit code for your TV's make from the list. The LED should then flash green twice. This shows you’ve entered a valid code
5. Press Volume Up / Down and Mute to check that the remote is working. If not, repeat the steps above using a different code for your TV from the list
6. Once you’ve programmed your remote you’ll notice that the light on the top will flash green instead of red when using it for volume and mute control
The remote can only store one device code type at a time, so you can’t control more than one TV, unless each TV works with the same code.
You can't learn anything from a mistake until you admit that you've made it.
  • 4.88K
  • 339
  • 829
Roger_Gooner
Superstar
Message 5 of 12
If none of the five Hisense codes works try 1999.
  • 6
pnat38
Message 6 of 12
I've tried doing what it said on the settings mode with programming the Virgin remote to the tv and it didn't work. Tried about 4 codes.
The green lights came on, but it wouldn't change the volume or turn off the TV.
Can anyone help?
Paul
  • 6
786-Waseem-786
Message 7 of 12
Hi try his go to program your remote by holding TV and clear when green light flashes type 0999 and the channel down approx 60 times or until TV goes off when it does press ok should flash green again and your sound should work, it is a little hit and miss with tv's made by Argos.
  • 6
pnat38
Message 8 of 12
Good evening
That never worked, tried what you said about 3 times.
The lights come on when required, but the volume doesn't alter.  When I go onto the help/settings function, the volume isn't even on anyway, so how do I know if it works as it's mute anyway.
  • 2.7K
  • 88
  • 137
Message 9 of 12
Hi pnat38,
Thank you for your post.  I'm sorry to hear you're having issues with the remote.
If you check out this link: virg.in/VTVremote it may be able to help further.
^Martin
  • 6
pnat38
Message 10 of 12
I'm not going to keep on trying as I've wasted a lot of time in doing this, obviously my hisense TV is not compatible with Virgin media.  Thanks anyway.
Paul
