Grubba
How to order a replacement tv remote.
When I ring which option am I supposed to chose, have tried option 2, but just says about checking service and not how to request a new remote..
  • 5.66K
  • 910
  • 1.33K
Hero
Re: How to order a replacement tv remote.
Hi Grubba,
You need the TV Faults option when dialling 150 from your Virgin landline, or 0345 454 1111, but best to call at 8am to avoid call queues
You could try the text messaging service.
Just send  a text with a description of new remote  to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
For now you could download the TV Control app and use that until you receive a replacement remote
https://www.virginmedia.com/shop/tvgo-tvcontrol
Dave
