  • 8
How to make Samsung smart remote use RF to control V6 in wooden cabinet
How can I make my Samsung smart remote use RF to control V6 in wooden cabinet
  • 17.26K
  • 1.82K
  • 4.08K
Re: How to make Samsung smart remote use RF to control V6 in wooden cabinet
Shouldn’t you be asking Samsung that question? It’s their remote.
Personally, with no experience of Samsung, I doubt that’s possible.
  • 8
The first time I asked Samsung, they said I needed a new remote which they supplied, but this didn't cure the problem. I now understand that the Samsung smart remote is RF, so it should operate the Virgin V6 in the cabinet, but it doesn't. If I open the cabinet door the Samsung smart remote will operate the V6 even from the other side of the solid wall in the hallway, but the minute I shut the cabinet door the remote doesn't work, even though the Virgin V6 remote which is also RF will work with the door shut
It's as if the Samsung remote isn't strong enough to get through the wooden cabinet door
  • 4.31K
  • 453
  • 755
Community elder
Hi I notice you have multiple posted virgin themselves will respond, but you confuse the issue and delay a response.Regards Micky
