How do I order a replacement remote control?
I've tried everything possible to get my TiVo remote to work after it suddenly stopped. Stupid amounts of new batteries but nothing's happening. The only hope was a red light flashing twice when the batteries are replaced but after that's happened, the remote is non responsive.
Searched online and spent over 20 minutes waiting for customer service to answer to order a replacement but as expected, I'm stuck with the app and a faulty remote.
  • 10.5K
  • 1.17K
  • 5.02K
Re: How do I order a replacement remote control?
It has to be done via hone via customer services. Select TV faults. It cannot be done via the Forum.
Click to learn more about VIP
Use Kudos to say thanks
  • 167
  • 24
  • 40
Superfast
Also, try pressing clear and TV. Thumbs down 3 times. Then OK. Just to be sure.
