Help tv - catch up / on demand not working
59Beverley
We are unable to watch catch up or on demand on tv  Engineer called last Saturday who said the problem was outside our house , he was unable to resolve the problem as it needed  different engineers  who were due to fix the problem last Monday. It's still not working!
1 ACCEPTED SOLUTION
Accepted Solutions
japitts
What happens when you try using OnDemand - do you get any error codes? That would give a strong clue to the cause.
Is your live TV OK? That would prove the incoming co-ax working.
By posting on here, I presume your home broadband is working? That's what provides the internet connection for your V6.
Which then leaves the connection between your V6 and home-hub. Is that direct Ethernet cable or wireless?
3 REPLIES 3
japitts
They apparantly need to dig up outside and need council permission to do so hence the delay until the beginning of Dec
Hi 59Beverley 👋🏼.
Thank you for posting and welcoming you back onto the community forum 😊.
Sorry to see there has been a delay in digging up outside to put the line in ☹.
Have our team advised what day in December?
Let us know how it goes.
Ari - Forum Team
New around here? To find out more about the Community check out our Getting Started guide
