mrflavell
  • 8
Help function not going to help
I've set up my new Tivo V6 box about an hour ago. I want to set up the remote to control the TV sound.
Going to  - Home > Help & Settings > Help - just gets me back to the - Home > Help & Settings - screen, not to Help itself.
Will this resolve itself in due course or is there a problem that needs some action?
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Re: Help function not going to help
Hello
Have a look at https://community.virginmedia.com/t5/Help/Programming-your-TiVo-remote-control/td-p/3166540 explains it all.
Regards Mike
  • 7.88K
  • 1.16K
  • 2.14K
Hi mrflavell,
Is this the link that only brings up a video on the right hand side and a picture of the remote instead of explaining how to set it up? virgin-tv-using-tv-remote
I've checked and the links work on this page setting up remote
You can also go to Home > Help and Settings > Help > then at the top of the screen Program Your  Remote.  Follow instructions there it should give you a series of codes to try.  You can also put 0999 in place of the code and press channel up until the TV turns off, then press ok.
There's also an online PDF with a list of  TV Remote Codes
You can also download the tv-control-app  to use as a standby remote.
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
mrflavell
  • 8
Thanks for your help. I've got it set up now, entering a specific code from the list.
  • 7.88K
  • 1.16K
  • 2.14K
Hi mrflavell,
Thanks for the update. Good to see it's all set up now.
Take care and stay safe.
Dave
mrflavell
  • 8
This must be one of those functions that takes a while to come through on a new set up. Home > Help & Settings > Help is now going to the help system as expected.
