on 19-04-2023 23:15
Hi there
My box has failed – just get the green screen saying it's detected a serious fault, then it tries to reboot itself endlessly and keeps failing.
Can you please send me a new box, as from what I can see online it's not something that can be fixed.
Anyway let me know as soon as you can,
Thank you.
Answered! Go to Answer
on 20-04-2023 00:55
The, "the DVR has detected a serious problem and is trying to fix it; do not switch off for 3 hours”. message is commonly known as the green screen of death. It means that your hard drive has failed. It's not very often that the box is able to recover from this, and if by some miracle it does, then it's only a matter of time before it fails completely.
You should call 150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults) although best time to call is around 8am when lines first open and are least busy.
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
on 20-04-2023 00:55
on 20-04-2023 13:57
Thanks, I called them and they are sending me a new box apparently. So should be with me in a week or so!
on 20-04-2023 17:45
@benbobjim wrote:Thanks, I called them and they are sending me a new box apparently. So should be with me in a week or so!
Fault replacements are usually done by tech visit - they will fit a new box and take your old one away.
Check your online account for orders showing,
on 20-04-2023 18:41
I asked the chap this and he said they wouldn’t send an engineer, just a box with instructions and a prepaid post bag to return the failed unit.
on 23-04-2023 10:42
Hi @benbobjim
Welcome to the community forums
Sorry to hear you've an issue with your set top box. I can see that you have had an appointment and this has since looked to have been resolved. Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
