Yanh
Have 2 x V6 boxes: Should both be hard-wired ( coaxial or Ethernet?) or can I do1 hard-wired/1 wireless?
I have 2 x V6 boxes. For full functionality must both be hard-wired. ( here, coaxial or Ethernet possible/best?) Or can I have just one hard-wired via coaxial and the other linked via wireless? If wireless OK, would the wireless option need a booster via power line etc. and would this be OK for 4K output? Thanks.
Tags (1)
  • 15.87K
  • 2.1K
  • 4.98K
Re: Have 2 x V6 boxes: Should both be hard-wired ( coaxial or Ethernet?) or can I do1 hard-wired/1 wirel
Hi @Yanh
Both boxes require a coaxial connection for the live TV.
You need either a wireless or ethernet connection for the catchup, on demand, EPG and system updates.
Dave
Love, love and love, forever - Pele
japitts
  • 20.68K
  • 2.65K
  • 4.74K
Just to clarify.. all VM TV boxes need 2 connections..
1: Co-ax cable, this is what carries your live TV channels
2: An internet connection for OnDemand, streaming & various updates. Your homehub provides this - Ethernet is always recommended given the choice, but reliable wireless is often sufficient.
