Moogera
  • 117
  • 17
Up to speed
Message 1 of 16
Erratic Remote Control
About a week ago I had the V6 box changed due to the hard drive failing and since then the V6 remote is behaving erratically,with TV functions.
The problems are,Volume up/down either works or doesn't,TV standby same either works or doesn't.
I have reprogrammed the remote and changed battery's but no difference.
Do I need a new remote?
  • 10.48K
  • 1.44K
  • 3.09K
Message 2 of 16
Re: Erratic Remote Control
Hi Moogera,
the original remote should work with the new box.
Did you try resetting it first - picture below?  Then follow the instructions on <<< this page >>>
Dave
Moogera
  • 117
  • 17
Up to speed
Message 3 of 16
Thanks yes I have done all that sequence.
And yes you are correct it shouldn't need resetting but when the Engineer left neither the volume or standby worked at all.
Serena_C
  • 2.17K
  • 90
  • 224
Message 4 of 16
Hi @Moogera,
Thank you for your post regarding the remote control issues you have been experiencing.
I have ordered a new remote to be sent out to you, please do let me know when it arrives 🙂
Best wishes,
Serena
Moogera
  • 117
  • 17
Up to speed
Message 5 of 16
Serena_C
  • 2.17K
  • 90
  • 224
Message 6 of 16
Happy to help Moogera!
Do keep me posted on how things are going when your new remote control arrives 🙂
Thanks!
Serena
Moogera
  • 117
  • 17
Up to speed
Message 7 of 16
Received new remote it will not flash green to allow me to input the code for the TV
Just flashes red
Robert_P
  • 4.02K
  • 189
  • 370
Message 8 of 16
Hello Moogera
Details on setting up the remote can be found here, if you need us further please let us know.
Rob
Moogera
  • 117
  • 17
Up to speed
Message 9 of 16
Yep done all this,the green led will not flash,changed batteries just to be certain but nothing
Kath_F
  • 31.41K
  • 1.2K
  • 2.5K
Message 10 of 16
Thanks for coming back and confirming this Moogera.
Can you try following the information here. Select that the remote isn't working and it should take you through some steps. If a replacement is needed then you can order one then too 🙂
Keep us posted with how you get on.
Kath_F
