Does the EPG match what's listed on https://www.skysports.com/watch/tv-guide ?
If the broadcaster goes off a published schedule to cover a live event, there's little VM can do.
If a schedule changes last-minute, again not much VM can do.
The V6 does have the facility to set manual recordings, so it's not impossible to record programmes if the EPG isn't accurate for whatever reason.
