Tomperrins
Message 1 of 8
Do second box need to be Hard wired in?
I recently received 2 tele box’s, the one downstairs is all set up with wires plugged into the “virgin wall box”. For the second one does this also need to be plugged into a virgin wall box or can this simply run off WiFi? I don’t fancy having a virgin wall box installed in my bedroom. Any help please! Thank you 🙂
DJ_Shadow1966
  • 7.13K
  • 1.36K
  • 2.02K
Message 2 of 8
Re: Do second box need to be Hard wired in?
Hello
All TV boxes require a coaxial connection from the VM network.
Regards Mike
LittleMick73
  • 5.03K
  • 520
  • 864
Superstar
Message 3 of 8
Hi was this installed by an engineer if so why did he not run a cable via a splitter to the 2nd box. Regards Micky
Emma_C
  • 8.28K
  • 512
  • 559
Message 4 of 8
Hi Tomperrins,
I do apologise for the delay in getting back in touch, we have been busier than normal.
Have you since been ale to get your second box set up?
Was this an install by an engineer or a self install?
Do let us know so we can assist further.
Emma_C - Forum Team
Tomperrins
Message 5 of 8
It was a self install. Only recently joined for the tele, always had the broadband so only have one virgin wall socket! I haven’t Thor the second box going yet. Thank you for getting back in touch 👍🏻
Tomperrins
Message 6 of 8
Was a self install Micky. Not to worry it’s not the end of the world. Thanks for getting back! 👍🏻
Tomperrins
Message 7 of 8
Hi mike, thanks for getting back to me. So for a dummie like me, does this mean yes it needs to be hard wired into a virgin wall box?
thank you again, 🙂
nodrogd
  • 16.81K
  • 1.97K
  • 4.08K
Message 8 of 8
thank you again, 🙂
The boxes have linear broadcast cable tuners & just as Freeview needs a rooftop aerial & Sky needs a dish connected by coax, your VM boxes need a direct connection to Virgin’s coax to work. They use the same technology. Second boxes should not be offered self-install for this very reason.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
