Matilda001
  • 28
DVR has detected a serious problem
My TV screen turned to a green page an hour ago with the a message saying 'DVR has detected a serious problem'.  I have done a service status scan which shows no problems, and also no similar problems being reported through other social media channels.  Is this matter likely to rectify itself, or has the box died?
nodrogd
  • 16.78K
  • 1.97K
  • 4.07K
Re: DVR has detected a serious problem
You are experiencing the dreaded "Green screen of death" I'm afraid.
Usually this is the result of a failed box hard drive which means the box will have to be replaced.
Give faults a call on 150 from your VM phone, or wait a day or so here for the Forum Team to respond.
VM BB TV Landline PAYG mobile. Freeview/Freesat HD, Tesco Mobile. Customer since 1993
Matilda001
  • 28
Thanks for the reply.  I had looked up online about the error message and had seen the 'green screen of death' comments.  I called Customer Service and an engineer is coming out on Saturday afternoon.  So, no TV till Saturday at the earliest.
japitts
  • 11.96K
  • 1.66K
  • 2.55K
You might find your TV has an in-built Freeview tuner to cover the basic channels, and you can try using VM's TV Go app if you have a compatible device...
https://www.virginmedia.com/virgin-tv-edit/tips-and-tricks/download-the-virgin-tv-go-app
Matilda001
  • 28
Thank you for the helpful advice, I will try the link via my laptop and see if that works.
Zak_M
  • 4.36K
  • 257
  • 413
Good morning @Matilda001
Did the engineer manage to resolve the problem?
Kind regards,
Zak_M
