SharonWatt
Just joined
DVR has detected a serious problem
Hi, I'm getting the message 'The DVR has detected a serious problem and is now attempting to fix it'
Having read other posts on here I think I need a new box as this message has been appearing since first thing this morning. I can't get through to anybody on 150.
  • 6.48K
  • 1.01K
  • 1.6K
Re: DVR has detected a serious problem
Hi SharonWatt,
Sorry to see you are havaing major problems with your V6 box. You generally need a replacement box when the hard drive has failed.
Have you tried signing into Service status at the top of this page and run a test against the TV box? By doing this VM should be able to send a signal to your box and try to repair it. Hopefully the automated system will recognise the issue and send out a replacement.
If that doesn't work then you need to contact the Faults team.
You could try the text messaging service. Just send  a text with a description of TV Faults to 07533 051809. Your message will go into a queue and a representative will respond to you as soon as possible. It may take a few days.
You can call (again)  150 from a Virgin landline, or 0345 454 1111, options 1,1 and 2 (Faultsbut best to call at 8am to avoid call queues
When calling Faults you will go through a series of questions/tests, if that doesn't resolve the problem then call back around 10 minutes later and an agent should pick the phone up
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Steven_L
  • 5.28K
  • 371
  • 538
Hey @SharonWatt,
Sorry to hear that you've had issues with your TV services.
I have been able to locate your account and can see that you have been sent out a new box, is everything now ok with your new box?
Steven_L
