Lukea654321
DVR has detected a Serious Problem in V6
Hello,
Our V6 Box seems to be broken, it doesn't switch on, instead it displays the message "the DVR has detected a serious problem and will attempt to fix, this could take up to three hours", so we leave it on overnight, but still it doesn't start up, after each three hour repair attempt it displays the same error message above.
I have tried the online chat with no success and I tried calling on my phone but it ran out of battery three hours into being on hold.
 Please advise on any method to get this fixed, thank you.
japitts
  • 12.09K
  • 1.68K
  • 2.6K
Re: DVR has detected a Serious Problem in V6
As you have surmised, this error means your hard drive has failed and you need a new box. It's not repairable.
The quickest way of getting this reported will be to call in, perhaps try a different time of day when wait times are shorter. Good luck
Lukea654321
Thanks for your advice.
I finally got thought to someone and they booked an engineer to come and look at the problem. Wouldn't it just had been easier to send out a box to swap out? Do engineers carry new boxes with them?
japitts
  • 12.09K
  • 1.68K
  • 2.6K
Quite often this would be resolved by a box replacement, yes.
Engineers will carry replacement boxes with them, so it shouldn't be a problem.
