on 07-12-2021 17:31
My TV box has not been working for 6 days. I have called three times and gotten nowhere. The box is on a constant loop of 'starting up' , welcome screen, switching off, displaying a green screen with text saying 'The DVDr has detected a serious Problem, it will take 3 hours to fix it.' I have unplugged everything, switched off and on again I don't know how many times. At my wit's end. Fed up with virgin. Need help please
Answered! Go to Answer
on 07-12-2021 18:41
The green "DVR has detected an error" message means your box's hard drive has failed and you will need a replacement box.
There's 2 ways of reporting faults, this example is no exception...
1: Call in. 150 from a VM phone or 0345 4541111 from any other phone and choose the "I have a fault" options
2: Wait on here for staff to respond, which may take a couple of days.
on 07-12-2021 18:41
on 07-12-2021 19:04
Great thank you! That's very helpful I will call the number 👍👍
on 09-12-2021 19:45
Thanks for your post and welcome to the Community Forums, Charleyv,
japitts is 100% that's definitely a hard drive error. Our records show that you have since been in touch. Don't forget you can view and manage your appointments online here
Cheers,
Corey C
