Keirasma
  • 5
Connection issue on v6 box
Hi, getting various error codes on my v6 box, so far C217, C233 C501. The box won't connect to the internet. I've restarted the box, unplugged it, reset the network connections and still nothing. Box upstairs connects fine. Any suggestions??
Tags (1)
kizi
  • 210
  • 41
  • 38
Re: Connection issue on v6 box
I will pm you to see if I can help
Robert_P1
  • 353
  • 62
  • 77
Have you tried connecting the box with the errors using the connections upstairs and see if it works?
Please send me a private message, not reply or quick reply, with your account number and area code/ postcode and I'll look into it for you.
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
Rob
