DaveYoung1959
Message 1 of 10
Connecting V6 box to TV with 15 meter HDMI cable
I have been trying to connect my new Samsung RU7400 TV to my V6 box using a 15 meter HDMI cable without success. A friend suggested that it wouldnt work as the cable was too long for the 4K data. Any suggestions how I get round this (problem is the route of the HDMI cable requires a lengthy cable).
Thanjs in Advance
Nicholas_k
  • 202
  • 37
  • 49
Message 2 of 10
Re: Connecting V6 box to TV with 15 meter HDMI cable
Hi,is this definitely a uhd cable ? If not it won’t work,it should have nothing to do with the length,I hope this helps.
ozsat
  • 4.42K
  • 312
  • 819
Community elder
Message 3 of 10
You may need to get a fibre optic HDMI cable.
Thanjs in Advance
VIVID 600 (690/44mb) in Area 31
dannylau
  • 11.11K
  • 902
  • 2.49K
Message 4 of 10
Normal UHD cables don't work reliably over about 3 meters
DaveYoung1959
Message 5 of 10
  • It's a:
Description
15M Meter V1.4 HDMI Cable Gold Plated Ends.
dannylau
  • 11.11K
  • 902
  • 2.49K
Message 6 of 10
https://www.amazon.co.uk/RuiPro-Hybrid-Fibre-HDMI-cable-Black/dp/B07287LTRZ/ref=sr_1_15?dchild=1&key...
DaveYoung1959
Message 7 of 10
Thanks for that. Problem I have is routing a new cable as HDMI cable was routed during a house conversion and now touting a new cable wouldnt be easy
ozsat
  • 4.42K
  • 312
  • 819
Community elder
Message 8 of 10
Worth a read - Need a Long HDMI Cable for 4K?
dannylau
  • 11.11K
  • 902
  • 2.49K
Message 9 of 10
The problem with HDMI cables is they can and do go wrong and need changing regularly to keep up with the latest tech, running them in walls is a bad idea long term
BenMcr
  • 21.44K
  • 2.34K
  • 4.3K
Message 10 of 10
Appreciate this starts to get overkill, but if you start down the Fibre route you should really keep the ends 'netural'. Something like this could be better idea - as it would allow you to swap the termination points at later stage for different standards in the same way that Virgin Media can do it with the HFC network.
https://www.amazon.co.uk/dp/B07Q2XVBW6
