Walkermeacher
Channels won’t load - stuck on 16%
Hello
TV box is connected by wifi to hub.  But channels won’t load.  On demand and apps are ok.  But channels stuck on 16%.
Any advice?
jb66
  • 12.43K
  • 926
  • 1.83K
Re: Channels won’t load - stuck on 16%
This means you havent connected the white coax to the box
Walkermeacher
Thanks v much - but I want to use it on wifi.  Coax is in different room to television .
Do I have attach coac to do this for initial set up?   Then it will work with wifi?
Or is it not possible to use wifi for channels?
Thanks so much.
japitts
  • 14.52K
  • 1.93K
  • 3.31K
No, the coax is what carries your live TV channels and all Virgin TV boxes require a coax connection.
The internet connection is used for OnDemand services & TV Guide updates (among other thing) which is where the Ethernet or WiFi comes in.
Virgin Media is a cable-TV platform, and the co-ax is the cable 🙂
