Buddybun
Channel guide issue
I am only seeing the epg for the Sky channels and the rest are just showing as To be Announced.
I have turned off the box and let it reboot and still the same issue where the Sky channels populate but the others don’t .
Any fix that anyone knows for this apart from moving to Sky?
Tags (1)
nodrogd
  • 16.45K
  • 1.92K
  • 3.93K
Re: Channel guide issue
Home>Help & Settings>Settings>Network>Connect to the Virgin Media Service now>
This will take about 3 minutes to run & should restore the data. If it doesn't there is a network fault or a problem with the box.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
