Beemer
  • 468
  • 7
Superfast
Cardboard box too small for return
I just have had my failing Tivo replaced with a V6 box.   The box this came in is too small to fit the Tivo to return it.  How do I get the proper sized box?
Tags (2)
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Re: Cardboard box too small for return
Hello
If it is a Tivo then VM dont require those back you can check what device are  required to be returned at https://www.virginmedia.com/help/virgin-media-return-or-recycle-equipment.
Regards Mike
keithse
  • 2.56K
  • 192
  • 522
Problem sorter
Old TiVo boxes do not need to be returned, they can be recycled at your WEEE bin at the local refuse tip.
See here:
Keith
