Can't order a replacement remote control
ARiley
The buttons on the left hand side of my remote control have stopped working, tried reset/repair nothing helped, trying to order a replacement but keep getting a fault message and try again
4 REPLIES 4
roy247
Superstar
If the online help isn't working then quickest way to get a remote would be to call 150 from your Virgin phone, mobile or landline, or 0345 454 1111 from any other phone or wait for a member of the forum team to pick this up which could be 2 to 3 day's.
Ryan_N
Hi ARiley,
Thank you for your post!
Sorry to hear about the issues you're having with your remote. I can see from our side you've not been able to speak with the team about this - I will pop you over a private message so I can arrange for this to be sorted.
Cheers,
Ryan.
So received an empty envelope this morning, seems somebody forgot to put a new remote in the envelope.
Paulina_Z
Hi @ARiley,
Thank you for coming back to us about this issue and I'm very sorry that you've not received your remote! I understand that you were chatting to a colleague via Private Messages. Please go back to them and they'll be able to assist on this issue further and have another remote sent out to you.
Thank you.
Paulina_Z
