I'll expand slightly by means of explanation..All VM TV boxes need 2 connections to work..
1: The co-ax cable that provides live TV channels, and 2: An internet connection for OnDemand, streaming & various updates
The TiVo has both of these connections provided via the co-ax cable, and the internet connection is inbuilt.
The V6 only has TV service via co-ax, the internet comes via your home-hub, this connection can either be Ethernet cabled or wireless.
So whilst there is no issue with swapping boxes between rooms (it's often suggested on here as a troubleshooting method if one box seems to have a fault), bear the connectivity in mind where internet-based functionality is concerned.
