Jude2
  • 90
  • 7
Dialled in
Message 1 of 11
Box not updating tv guide
My v6 box doesn't seem to be updating the tv guide. On the system setup page it shows that it's updated to Sunday 24 April. I thought that it should at least be Monday 25 by now?  When I forced a connection it successfully connects but doesn't download or update anything. I have rebooted the box in case that was the issue, but still it connects successfully but doesn't update the guide.  Is it just me? Or is it that the network isn't updated since the weekend? Help and any advise would be grateful
nodrogd
  • 18.74K
  • 2.23K
  • 4.85K
Message 2 of 11
Re: Box not updating tv guide
For most of the Public Service channels (BBC, ITV, C4,C5), schedules are only published a week in advance. The rest vary between 1 & 2 weeks of data. It’s only some of the Sky channels that populate the full 2 weeks.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
Jude2
  • 90
  • 7
Dialled in
Message 3 of 11
Thanks for the help, but I have no programme info for any channels after Saturday 22. Not sure if this is nationwide (problem with VM network not updating) or my box, because I can force a successful connection however there doesn't seem to be anything to download to my box to update the tv guide? Probably I'm just worried about nothing and it'll finally update eventually, but given the fact that it usually has something to update every 6 hrs I find it strange that nothing seems to be updating.  Again thanks for any help. Anything to put my mind at rest.
japitts
  • 20.65K
  • 2.64K
  • 4.73K
Message 4 of 11
Do you have listings for the following channels beyond April 22nd?
Discovery HD 250, Eden-HD 247, Sky Sports F1 HD 506, DMAX-SD 171
I've intentionally picked those to cover a variety of broadcasters, which currently do have listings on the 23rd.
Jude2
  • 90
  • 7
Dialled in
Message 5 of 11
Ok so spoke to a few friends who have VM and they have all rang 150 about something today, they have all been told to either reboot their box, hub or both.  Now there is nothing on the service status page saying they have an issue in their area. I've also spoke to the call centre on 150 I was told if the connection is successful then I have the most up to date tv guide?  As I said I have already rebooted my box, I have also rebooted my hub -tried to force a connection, again although successful it still says the t.v. guide is up to Sunday 24th. I wonder if it's nationwide VM issue with the network just not updating as usual every 6 hrs? Anyone else having this issue.  I'm sure it will eventually get fixed. Fingers crossed.
japitts
  • 20.65K
  • 2.64K
  • 4.73K
Message 6 of 11
This is a good summary - if you could answer the questions in my previous post, the one you've just replied to... that will help ID if there's a problem with your TV guide listings or not.
If there was a nationwide issue, this forum would be chock-full of users reporting problems - and I don't see any evidence of that. My TV guide is also fine.
Jude2
  • 90
  • 7
Dialled in
Message 7 of 11
They are showing for 23rd but I have absolutely nothing for 24th at all. Any ideas
japitts
  • 20.65K
  • 2.64K
  • 4.73K
Message 8 of 11
Yep, my TV guide is exactly the same and yours therefore appears to working normally.
Sky Nature SD/HD on 279/280 has listings for the 24th, but not every channel has a rolling 14day guide - this is not a fault.
Jude2
  • 90
  • 7
Dialled in
Message 9 of 11
Thanks, can I just check, when you go on the status page on v6 and it shows what date the TV guide goes up to, what does yours show
japitts
  • 20.65K
  • 2.64K
  • 4.73K
Message 10 of 11
I'm not sure what you're asking, you can only view the status of your V6's network connection which you've already checked.
As already advised by @nodrogd above - not all channels have a rolling 14day EPG. Sky-branded channels tend to, a couple of the other pay-TV broadcasters have around a 12day thing, while the terrestrials & FTA only ever go upto "a week Friday".
They then populate the second week during Friday-Sunday. Your V6 will dial-home every 6hours and obtain the most-current EPG data at that time.
