rdnw40746
Bose Solo 15 TV Sound System
Help needed! Bose will not accept code from remote. I have a Tivo V6 box. The Bose used to work from the Tivo remote but I can not find a code that works now.
Cheers
  • 6.55K
  • 1.02K
  • 1.63K
Re: Bose Solo 15 TV Sound System
Hi rdnw40746,
I'm not sure if you've used theses but there are 3 codes for Bose systems on the audio_remote_code_list.pdf  1070,1170 and 1224.
Make sure your remote is disconnected from any other devices prior to setting up with AV Receiver.
Press and hold down Clear and press Volume Up at the same time, until the light on the top of the remote flashes green twice
Enter the four digit code from the list. The LED should then flash green twice. This shows you’ve entered a valid code
Press Volume Up / Down and Mute to check that the remote is working. If not, repeat the steps above using a different code for your AV device from the list
The remote can only store one device code type at a time. This means that you can’t control two AV devices at the same time.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
  • 6.55K
  • 1.02K
  • 1.63K
If the above fails you could also try the long winded method.
Make sure you have new batteries in the remote, and a basketful full of food and drink.
This time make sure the AV device and your TiVo box are switched on
Press and hold down Clear and Volume Down at the same time until the light on top of the remote flashes green twice
Enter the code 1999 to access the AV device code database – the LED will flash green twice
Point the remote at the AV device and press channel up repeatedly until a code mutes the volume for the device – the LED will flash green each time a code is sent. When the volume turns off, press Mute to turn the volume back on
Press Volume Up / Down and Mute to check that the remote is working with your device. If it doesn’t work, continue to search using Channel Up until the next code turns off the volume, and repeat  the above steps
When the Volume and Mute keys work, press OK to store the code. The LED will then flash green twice.If you reach the end of the code database, the light on top of the remote will give an extended red flash and exit programming mode.
Dave
