Willownep
Just joined
Been sent return packaging for Hub but not TV box
I've recently left Virgin and been sent enough return packaging for the Hub but not the Tivo box. On the returns letter it only mentions the hub as well. Does this mean I don't need to return the Tivo box? I don't want to be charged for it.
  • 7.86K
  • 1.16K
  • 2.14K
Re: Been sent return packaging for Hub but not TV box
Hi Willownep,
It depends which equipment you have. You can check which items VM want returning here return-or-recycle-equipment
Dave
Problem Solved? Click to mark as a Helpful Answer or use Kudos to say thanks for a useful post
