rutters
  • 12
Message 1 of 19
Basic V6 box connection.
Just got a V6 box out of the attic but all the cables have gone (except power cable).
Could anyone tell me which cables I'll need and where they go please/
japitts
  • 17.19K
  • 2.24K
  • 3.95K
Message 2 of 19
Re: Basic V6 box connection.
When you say "got a V6 box out of the attic", can you elaborate?
VM's cabling - if required - should be installed by VM techs as part of a manned install.
The box needs a coax cable connection which connects to the white flylead into the "coax" connection on the back. The internet connection via your homehub can be via Ethernet or WiFi.
rutters
  • 12
Message 3 of 19
Yes sorry,
I have VM broadband already running with a Hub 3
thanks
Anonymous
Not applicable
Message 4 of 19
VM will send you the box that will work when you subscribe to the tv service. you can't just connect a box that isn't part of your subscription
rutters
  • 12
Message 5 of 19
It was part of my subscription but  disconnected it and just used freeview
Anonymous
Not applicable
Message 6 of 19
Was? so its not now?
It will not work you will need to resubscribe. the box should have been returned when you ended the tv service
japitts
  • 17.19K
  • 2.24K
  • 3.95K
Message 7 of 19
How long ago did you disconnect it? There's a few issues that this raises, namely non-returned equipment and an extremely strong likelihood of the box having been deactivated.
rutters
  • 12
Message 8 of 19
My subscription is the same, I just disconnected the box
rutters
  • 12
Message 9 of 19
Disconnected approx 6 months ago.
Does the V6 box get the TV signal from the Hub 3 or TV aerial?
japitts
  • 17.19K
  • 2.24K
  • 3.95K
Message 10 of 19
Edit: thanks for confirming.
V6 boxes are actively sought back by VM when TV services on a given account are disconnected, and the box is certainly deactivated.
That you've not returned it, means something has gone wrong. Following the wrong process to reconnect it (i.e. expecting it to just plug in and work) is very much a case of "two wrongs don't make a right"
As regards where the V6 gets its signals from.. TV signal comes along the coax cable, the internet connection is used for OnDemand, streaming & EPG updates. Virgin Media is a cable service, your TV aerial is used for Freeview services which have nothing to do with VM.
