It means that, anytime a programme that's available on iPlayer but not listed on the TiVo/V6 EPG, you'll have to load the iPlayer app manually and play it that way - yes.
It shouldn't be happening with "CatchUp" programmes.
A bit like the ITV, C4 & C5's streaming apps having additional programmes that aren't otherwise available - consider it a bonus 😉
