  • 5
BBC, C5 and ITV programme info not displaying in guide on V6 box
no program info available for any BBC1,2 and 4 and ITV1,2 on V6 box
For past few weeks one of our V6 boxes has stopped displaying program guide info for BBC1, 2 and 4 and Channel 5 and ITV1 and 2
All that appears is : To be announced.
All other cable channels are displaying content.
Box has been rebooted; network checked etc.  The other V6 box works fine and is connected to same network.
Any ideas?
  • 15.57K
  • 1.63K
  • 2.65K
Re: BBC, C5 and ITV programme info not displaying in guide on V6 box
How is the problematic V6 connected to the Hub? if not on a direct ethernet (Cat5e/6) cable try it on one and see if it that sorts it.
  • 4.05K
  • 280
  • 702
Community elder
It is normal for BBC, ITV and Channel 5 to only have listings to Friday next week - and then TBA after that.
VIVID 500 (500/35mb) in Area 31
  • 5
It was showing NO current  (or future) programme info at all for those channels .  Then last night without intervention the programme info all started to appear on that box.
  • 5
Wifi.  But a second box connected to same Wifi worked perfectlt so was box related.  However last night the current and future programme info started to appear without our intervention.....
  • 15.57K
  • 1.63K
  • 2.65K
Because the 2 V6's are (presumably) in different locations, they will not be receiving the same strength wifi signal and subject to different levels of interference. Its most likely that one dropped out for a while and the other didnt - then as interference went down - it reconnected.
If you can - connect them to the Hub by Cat6 ethernet cables to avoid wifi issues.
