alun101
  • 7
Audio Problems
I have the V6 box connected to the TV via HDMI.
I’ve noticed that the audio volume of adverts is at least 50% louder than the programme, it’s especially bad with films.  This is across every channel.
I’ve tried changing the audio setting between ‘Dolby Digital’ and ‘Digital to PCM’ and no difference. I’ve also swapped HDMI cables, no difference.
google search suggests this is not uncommon, but it is damn annoying.  Does anyone have a fix or if anyone from VM reads this, can you sort out the audio levels if your programmes
japitts
  • 10.57K
  • 1.48K
  • 2.13K
Re: Audio Problems
You're not alone in noticing volume differences between adverts & programmes.
I suspect there's not much (if anything) VM can do, if it's intentional on the part of the broadcaster. As seems likely.
LittleMick73
  • 4.94K
  • 513
  • 841
Superstar
Re: Audio Problems
Hi for as long as I can remember the adverts have always been louder, and indeed it is intentional by the broadcasters, and something Virgin have no control over. Regards Micky
