-Maelstrom-
  • 17
Message 1 of 5
2nd box not being able to connect to main box...
First world problems, eh?
I've been a customer for over 2 years and in the last week I've suddenly lost the ability to view recordings from the main box, on a 2nd box. I've just seen another thread where it recommended rebooting the router as well as the boxes, so I'll give that a go later, but are there any other options?
No error codes, just that the main box no longer appears on the 2nd box, but the main box still list the 2nd, and I can still access recordings from the 2nd box on the main one. At the moment, I've just restarted both boxes, checked connections and tried renaming them, just in case that would prompt a connection.
roy247
  • 3.3K
  • 284
  • 772
Wise owl
Message 2 of 5
Re: 2nd box not being able to connect to main box...
When I had 2 V6 boxes and had any problems like this I had to go to settings, network, connect to the virgin media services now, had to do this on both boxes sometimes it took 2 or 3 goes.
-Maelstrom-
  • 17
Message 3 of 5
Cheers. I'll give it a go. I think I've only reconnected with the 2nd box so far
japitts
  • 20.61K
  • 2.64K
  • 4.72K
Message 4 of 5
Can both V6 use OnDemand services OK? That uses the same connection, and is a good test.
-Maelstrom-
  • 17
Message 5 of 5
Thanks everyone. I seem to be sorted now, after rebooting both devices and, this time, the router. Both boxes could access OnDemand services, but now they can both 'see' each other.
