Kirky1972
Message 1 of 8
wall box to 360 coax cable
Recently joined virgin. Was told 360 box and router could be in separate rooms, but the provided cabling meant they had to be next to each other. Am now trying to get hold of the right coax cable between wallbox and the 360 box. Customer services said 'google it'. Any help greatly appreciated.
Anonymous
Not applicable
Message 2 of 8
Re: wall box to 360 coax cable
you can't install or change the cable yourself. you need to get VM to do it.
If the coax port was not in the right place you should of had a manned install
To modify it later may cost £99
Kirky1972
Message 3 of 8
wallbox coax cable
how can I get a replacement coax cable (wallbox to 360 TV box)? Customer services said they don't provide them, and to google it ! (tried that, and found 1000s of different connector types).
Anonymous
Not applicable
Message 4 of 8
Re: wallbox coax cable
already answered on your other thread.
do not create multiple threads for the same problem s this is against the forum rules
jonathanpye
  • 462
  • 17
  • 112
Fibre optic
Message 5 of 8
You need F pin to F pin cable as you should  already have a short female F pin to coax provided by VM that connects to the box. If no cable then its F pin to coax
Services and Equipment;
HUB4
x2 V6 Upgraded to tv360
Ultimate Ooomph Gig1 with UHD
VM Telly Tablet
speedy35
  • 22
  • 8
Message 6 of 8
Thought I'd already sent this link, nothing to stop you joining as many as you need
https://www.youtube.com/watch?v=7AwwEbte6_U
Anonymous
Not applicable
Message 7 of 8
other then the contract.
If you modify the cabling save a few £1000's for if they charge you for any noise ingress
jonathanpye
  • 462
  • 17
  • 112
Fibre optic
Message 8 of 8
Now I've read your initial circumstances.
You should request a VM engineer who will extend the wall point to the appropriate location. When I upgraded to multi room they came out split my downstairs box , threaded a very long cable around the house from the front to the bedroom at the back of the house and created a second wall box in that bedroom for the second v6 box.
You should not have to do such an install yourself.
HUB4
VM Telly Tablet
