bringer
virgin 360 tv box and samsung smart tv
i recently signed up to virgin tv i have the service 4 weeks now but every morning i turn tv box on i get a black screen with sound coming in and out i’ve tried every settings nothing works have had engineers out to my house 6 times they keep changing cables get it working and next morning same result a black screen please help
TiffanyGreen97
  • 357
  • 20
  • 92
Fibre optic
Re: virgin 360 tv box and samsung smart tv
what happens you turn of the box and turn it back on the power switch on the back
jonesy172
  • 9
It’s an issue with the tv box not having HDCP 2.2 enabled. He this issue for over a year on the v6 now on 360.
if you use a hdmi splitter it bypasses the HDCP version 2.2 and shows 1.6 and works without a glitch. Only down side is max resolution is 1080.
had virgin out countless times and they are baffled. Even got a new Samsung tv and same issue. HDMI splitter will get you going but vm issue
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Hello
The v360 does use HDCP 2.2 the older v6 didnt, as long as the cable is HDCP 2.2 then it will work, for this type of TS I first of would recommend changing the HDMI cable.
Regards Mike
