jeza64
  • 13
Message 1 of 35
sound and picture out of sync
HI, I RECENTLY UPGRADED TO VIGIN 360 AND SINCE THEN ALL MY CHANNELS SOUND IS OUT OF SYNC WITH THE PICTURE !! I HAVE TRIED ADJUSTING IT IN THE SETTINGS BUT IT DOES NOT WORK. IF IT  CANNOT BE FIXED  CAN I ROLL BACK TO THE OLDER SOFTWARE ??
roy247
  • 2.79K
  • 216
  • 640
Trouble shooter
Message 2 of 35
Re: sound and picture out of sync
No you can't roll back to TiVo software and become  a V6 again.
So we have to try and fix your sync problems, are you connected 360 to TV and using the TV speakers, or is there a soundbar involved.
Are you using HDMI arc if using a soundbar or fibre optic cable.
Have you tried the dolby settings in Audio and Video.
jeza64
  • 13
Message 3 of 35
TV Connected to 360 with hdmi and soundbar connected to tv with optical.
roy247
  • 2.79K
  • 216
  • 640
Trouble shooter
Message 4 of 35
You could try the 360 connected to the soundbar directly using the fibre cable and setting dolby to follow content.
Corey_C
  • 5.31K
  • 259
  • 454
Moderator
Moderator
Message 5 of 35
Thanks for your post and welcome to the Community Forums, jeza64,
Sorry to hear that our audio is not in sync. Have to been able to get this sorted since you post? Have you tried the online troubleshooter here: https://www.virginmedia.com/help/diagnostics/i-can-t-watch-my-tv/your-tv-sound-isnt-working
Cheers,
Corey C
jeza64
  • 13
Message 6 of 35
not fixed yet. waiting for a longer optical cable to connect direct to soundbar to see if that works..
Lee_R
  • 6.3K
  • 291
  • 656
Message 7 of 35
Hi @jeza64 thanks for getting back to us.
Do you mean you've ordered a longer optical cable from a 3rd party retailer?
Lee_R
jeza64
  • 13
Message 8 of 35
yes. it arrived a couple of days ago. I've tried a bit and I think it's a bit better but I need to check different channel's
Martin_N
  • 8.35K
  • 352
  • 511
Message 9 of 35
Thank you for that information jeza64.
Please do let us know how the channels are with the new cable.
^Martin
jeza64
  • 13
Message 10 of 35
so. its not been so bad but watched a film on prime last night and it was terrible!!
