narkymarky
Just joined
does any 1 no how to set tv guide to start at begging of tv channels
Does any one know how to put tv channels in order starting at 100 101 102 etc ect
  • 12.08K
  • 1.62K
  • 3.67K
Re: does any 1 no how to set tv guide to start at begging of tv channels
Hi narkymarky,
The main (shared) profile automatically lists the channels in that format. If you've added other profiles then if you go into Settings > Profiles you can select the Default profile on start up, which should be the main(shered) profile to keep the list in the order 101, 102, 103 etc.
If you set up other profiles then all but the main profile are numbered consequentially 1, 2, 3, 4 etc
Dave
