JanetteS
  • 47
  • 9
Dialled in
Message 1 of 10
Will VM move a coaxial connection box into another room
Hi there,
If a VM connection enters at the front of a mid terraced house (with only front and back external walls), with the TV point coaxial connection on the same internal wall (front room), can this be moved into another downstairs room (back room)?
Would it mean VM had to run coaxial cable from point of entry all through the front room, round the walls etc into the next room or is there some other way this can be done without visible cables?
Daughter is asking, she's considering buying a mid terraced house but wants to swap the front room TV into the back room.  Any idea if this is possible?  If it does have to be cabled,  would VM run cable under floorboards, drill through to back room etc?
If it turns out the ground floor is concrete, could cabling go up outside front wall and in through upstairs, then under floorboards and back down through ceiling to back room?
Is there another solution?
Any thoughts would really help please.
japitts
  • 18.18K
  • 2.35K
  • 4.16K
Message 2 of 10
Re: Will VM move a coaxial connection box into another room
Others are more familiar with some of the install specifics, but AFAIK most things are possible within the caveat that VM will only work upto first-floor level - they won't go into loft or roof-space.
Presumably this would be a transfer of existing services, but effectively a new install at the proposed property?
Roger_Gooner
  • 7.86K
  • 518
  • 1.48K
Message 3 of 10
Normally the installer will just drill through the internal wall. The cable can normally by run alongside or above the skirting board and hidden inside a cable cover, loads on sale from Amazon, Screwfix, etc. If you want the installation under floorboards the only way to guarantee that it's done this way is to lift them up yourself and put in a rope for the cable to be pulled through from the front to the back of the house.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
JanetteS
  • 47
  • 9
Dialled in
Message 4 of 10
Thanks for the quick reply.
She would be a new customer of VM, but the current house owners already have VM installed.
It may not even end up being this property she buys. But she's realised it will probably apply whichever mid terrace she buys.
Thanks for your advice re VM not going into loft/roof space.   I'm really hoping it might be possible, to move the box without visible cables.
Any thoughts on whether it would have to be a cable?
Thanks for your help
japitts
  • 18.18K
  • 2.35K
  • 4.16K
Message 5 of 10
Put it this way - Virgin Media is a cable operator, and the co-ax is the cable.
JanetteS
  • 47
  • 9
Dialled in
Message 6 of 10
Thanks for your quick reply.
Lifting the floorboards might be something she could consider getting a workman to do assuming the floor isn't concrete!
There's a fireplace to navigate round though, which would look ugly if it has to be surface cabled.
Are there not any non cable alternatives, do you or anyone else know?
Thanks for the advice.
JanetteS
  • 47
  • 9
Dialled in
Message 7 of 10
I guess I'm just not sure how helpful, or how much trouble the installer would go to... 🙂
JanetteS
  • 47
  • 9
Dialled in
Message 8 of 10
I was wondering if there was any other way...   for example by wifi?  Or some other way to get the signal from the existing box into another room for the TV, or does it always have to be a cable?
Roger_Gooner
  • 7.86K
  • 518
  • 1.48K
Message 9 of 10
Take a look at the big four Pay TV operators.
  • VM - coaxial cable for all TV boxes and hub
  • BT TV - coaxial cable from aerial to YouView box plus BT broadband
  • Sky - coaxial cable from satellite dish to main Sky box plus broadband
  • TalkTalk TV - coaxial cable from aerial to YouView box plus TalkTalk broadband
So, no escape from coaxial cable.
JanetteS
  • 47
  • 9
Dialled in
Message 10 of 10
Thanks all,
I guess from your replies it has to be cable.
Plenty to think about, and I really appreciate all your advice.
Thank you 😐
