Andrew1955
  • 10
Virgin v6 and 360 box volume
How do I improve the volume levels on v6 and 360 box? Thanks
Travis_M
  • 4.58K
  • 169
  • 335
Re: Virgin v6 and 360 box volume
Hi @Andrew1955
Thanks for posting on our community forum and sorry to hear you're having issues with your TV box(s)
Is the audio affected on every channel? Is your TV volume turned up to max using the TV remote, just to double check?
Travis_M
Applescruff
  • 22
I changed the audio output to PCM 5.1 (HDMI only) and it's loud and clear using Polk Magnifi2 sound bar with wireless sub.
