staceym23
  • 32
Message 1 of 10
Virgin tv 360 crackling sound
Can anyone help I got virgin tv 360 in and the mini box I can hear a crackling sound in the background on and off on some channel's especially on utvhd can this be fixed
staceym23
  • 32
Message 2 of 10
360 mini box sound issues
Can someone help whenever I am watching something on the mini box live or recorded I can hear a noise in the background but when I check the same programme on the main box the sound is not there it happens during any programme that I watch on and off I have tried moving the wire about but nothing helps
Tags (1)
staceym23
  • 32
Message 3 of 10
Help to fix 360 problem
Can someone help with getting intouch with someone to fix sound problem with 360 mini box
  • 6.51K
  • 1.02K
  • 1.61K
Message 4 of 10
Re: Help to fix 360 problem
Hi staceym23,
What are the sound problem issues?
For Sound issues go to Setting > Audio & Video - try setting Dolby Audio to always convert.
You can also try different settings such as follow content or disabled
 If you are using a sound bar try connecting the 360 to a TV HDMI port without ARC.
Then if you are using  fibre optic straight from the 360 to your sound bar, set Dolby to Follow Content.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
roy247
  • 1.03K
  • 82
  • 223
Knows their stuff
Message 5 of 10
I can see you have started 3 threads on this, that is if they are all " crackling sound " problems on the mini box. Is the mini connected straight to the TV or are you using a soundbar. Assuming both boxes are connected directly to the TV with no soundbar then you could try the sound settings, I have mine set to follow content NA uses always convert, easiest option if the sound settings don't work would be to swap HDMI cables, if that doesn't show anything you could temporarily swap boxes around to see if the problem follows the box.
Anonymous
Not applicable
Message 6 of 10
Re: 360 mini box sound issues
Is the sound coming from the broadcast or the mini itself? The mini contains a fan and often kicks in when using the box.
From my own experience, the fan on the mini does operate quite frequently and perhaps this is what you can hear?
Paul
staceym23
  • 32
Message 7 of 10
I have changed it to follow content will try that for a few days and see how it goes if not will try disabled and see how that goes thanks for the help
Akua_A
  • 1.23K
  • 31
  • 79
Message 8 of 10
Hi @staceym23,
Welcome back to our community forums.
Sorry to hear you are experiencing these sounds with your 360 mini box. We can understand your concern. I have been able to access your account using forum details. I see that you recently spoke to our team regarding this. Is the issue ongoing? Did you find the great advice given by our community helpful?
Please get back to me when you can.
Akua_A
staceym23
  • 32
Message 9 of 10
I changed the audio setting as I said above to disabled and it seems to have improved the sound for the most I think will leave it like that for a while and see how the sound goes
Beth_G
  • 3.45K
  • 214
  • 348
Message 10 of 10
No problem staceym23, glad to hear it has helped improved the sound.
If you'd like us to help further just let us know 🙂
Beth
