Gramarbec
Message 1 of 9
Virgin TV Box Power Cable
Hello,
I’m missing a power cable for the Virgin TV box 1008-C-STB-VM.
Please can someone help me get hold of a replacement.
Many thanks,
Grant
japitts
  • 20.68K
  • 2.65K
  • 4.74K
Message 2 of 9
Re: Virgin TV Box Power Cable
I'm fairly sure that's a 360 - can you confirm? Check here
We can then move this post to the appropriate TV forum where the staff can pick it up.
Gramarbec
Message 3 of 9
Thanks for the quick reply, yes it is a 360 box.
Grant
roy247
  • 3.34K
  • 288
  • 777
Wise owl
Message 4 of 9
Just to help the Forum Team do you have the power supply and are just missing the mains lead or is it both you need.
Gramarbec
Message 5 of 9
Hi I need the cable and the power supply, thanks.
Gramarbec
Message 6 of 9
Hi is anyone able to help with this?
roy247
  • 3.34K
  • 288
  • 777
Wise owl
Message 7 of 9
It usually takes the Forum Team a couple of days to pick things up the fastest way is to phone,  but then that depends on who you speak to.
Travis_M
  • 4.6K
  • 169
  • 336
Message 8 of 9
Hi @Gramarbec
Thanks for posting on our community forum
I'm going to drop you a private message now to confirm some more details, please keep an eye on your inbox.
Travis_M
Travis_M
  • 4.6K
  • 169
  • 336
Message 9 of 9
Hi @Gramarbec
Thanks for your reply
If you check your inbox I've dropped you a private message so we can get this sorted for you.
Travis_M
