on 26-02-2022 19:54
Even though both of my boxes are connected to my modem by wifi the 2nd box keeps coming up with an error when trying to play recordings,it says it cannot connect to box1
on 27-02-2022 00:40
I'm presuming you have a 360-master & a 360-mini, but can you confirm?
Can you use OnDemand services from both boxes, that's a good test of the hub connection.
27-02-2022 08:22 - edited 27-02-2022 08:25
@PaulThisy wrote:Even though both of my boxes are connected to my modem by wifi the 2nd box keeps coming up with an error when trying to play recordings,it says it cannot connect to box1
Make sure the main box is set to fast start or active start. Also try both boxes connected to the same wifi network, either both on 5g or 2.4g.
on 27-02-2022 12:07
Hi,thanks for your reply...weirdest thing,when i was trying On-demand services on the mini-box i tried the recordings and they now play 🤷♂️ i havent changed anything so it will remain a mystery.Thanks again.
on 27-02-2022 12:22
When you say your modem, do you mean the VM Hub or your own modem?
