Nabby58
  • 5
Message 1 of 10
Virgin 360 box and coax cable
Can anyone advise if you still need to connect coax cable to 360 box or if this has changed?
I have just agreed a new contract with Virgin.  I already has virgin broadband but sky tv.  I have cancelled sky and included virgin tv.  I was told I would receive a 360 box which arrived at the weekend.  When sorting this I told the advisor I only had a single coax cable coming from the box on the wall and going into the hub and asked if I would need a splitter or something for a feed into the tv box.  He sounded surprised and said no I would connect the hub and box with an ethernet cable.
All of the set up instructions indicate a coax into the tv box is required and I also did some searching online which indicated the same.  I called Virgin again at the weekend and explained this to the man I spoke to.  After putting me on hold he came back and said he had ordered me an ethernet cable.  I explained again that it was the coax connection I was enquiring about and already had an ethernet cable.  He also sounded surprised and said I should connect with the ethernet and gave the impression that the set up guide is out of date and was apologetic.
After looking online and coming onto this forum as far as I can see I definitely need a coax connection to get live tv and this may involve having to have an engineer out (at cost ) to set up.  Can any nice person or a moderator advise if this is still definitely the case before I ring Virgin yet again and probably get fobbed off yet again.  I obviously do not want to try to set everything up if I do not have all equipment/leads in place.
Thanks.
Tags (1)
  • 15.87K
  • 2.1K
  • 4.98K
Message 2 of 10
Re: Virgin 360 box and coax cable
Hi @Nabby58
I can confirm that you need to connect all VM Set top boxes (TIVO, V6 and 360 boxes) via coaxial
They need the coaxial connection to transmit live TV.
Dave
Love, love and love, forever - Pele
NinjaMeerkat
  • 460
  • 20
  • 92
Fibre optic
Message 3 of 10
Im shocked that neither advisor you spoke to knew how to connect their own device. How can anyone in VM's help desk not know how their equipment connects, this is basic knowledge.
nodrogd
  • 18.75K
  • 2.23K
  • 4.85K
Message 4 of 10
Second boxes cannot be self-installed. They must be installed by a tech so are included as standard & should show up as part of the installation/activation charges. This is no doubt offshore “telling you what you want to hear” rather than what you need to hear. They are just booking an install, not looking at what that install intails.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
BenMcr
  • 22.84K
  • 2.52K
  • 4.86K
Message 5 of 10
Thanks.
If you're adding TV to Virgin Fibre and you're happy to have it in the same room, then the delivery you get should have included all the appropriate coax cabling to add TV to your existing service.
Zach_R
  • 4.9K
  • 159
  • 337
Message 6 of 10
Hi @Nabby58,
Thank you for your post. I'm sorry to hear you're having a bit of trouble with installing some new equipment.
As I can see a few members of our community have advised, you would need to connect the equipment via a coax cable and it should've been provided within the delivery of the new equipment if you didn't have an engineer come to install it for you.
Have you managed to speak with the team since your last post about this? Let us know if you still need some help and we can go from there.
Zach - Forum Team
Roger_Gooner
  • 8.75K
  • 558
  • 1.66K
Message 7 of 10
If you received everything (splitter, two lengths of coaxial cable, an IEC connector cable and an Ethernet cable) with the 360 this is how you hook everything up. Disconnect the cable from the hub and connect it to the splitter. Connect the hub to the splitter and the 360 to the splitter via the IEC connector. Connect the 360 to the hub with the Ethernet cable.
|                      |---coaxial---hub---Ethernet cable
|---coaxial---splitter-|                    |
|                      |---coaxial---IEC---TV box
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Nabby58
  • 5
Message 8 of 10
Sorry has been a while since I posted.  On my third call to Virgin I yet again spoke to someone in a call centre who just did not understand what I was asking for.  I became quite frustrated with him in the end and he did book an engineer visit for me.
The engineer was brilliant - said straight away I needed a splitter, fitted it, tested, checked everything at local roadside box, linked box to tv, set up controller and ran through everything with me.  He said I should receive an email to give his visit a rating and did not which is a shame.  He stated that they have a lot of problems with customer service staff not understanding the customers needs.
So to recap - on initially negotiating new contract I explained my set up and said I thought I needed a splitter - was told no.  On arrival of kit I telephoned and explained I needed a splitter as I did not have coax connection to plug into box.  I was sent an ethernet cable.  On my third try he just did not seem to understand me and after putting me on hold many times he booked engineer visit.  Why are the customer service agents so inept?
Following all these my initial bill is now wrong - they are charging me more than previous contract rather than less, ie. have not applied discount shown on contract - will post on this under appropriate heading,
Lee_R
  • 6.89K
  • 326
  • 736
Message 9 of 10
Hi Nabby58, thanks for posting and welcome back to our community.
Sorry to hear you're having issues with connecting your TV 360 and monthly package price.  I would like to take a closer look on your behalf.  I am going to send you a private message.
Lee_R
Lee_R
  • 6.89K
  • 326
  • 736
Message 10 of 10
Hi Nabby58
Just a quick note to confirm you're satisfied with the response and efforts of the forum team?  Remember if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand.
Lee_R
