Paul365
Just joined
Virgin 360 Sound Problems - Panasonic Soundbar
I've recently joined VM and having voice sync problems with my Panasonic sound bar and Panasonic TV.
It starts off OK then within a minute or so starts to drift. I have tried resetting the delay without any real success.
Tried both HDMI to the sound bar & Optical connections both from the TV and the router.
I also have Apple TV in the mix
Any ideas?
  • 6.46K
  • 1.01K
  • 1.6K
Re: Virgin 360 Sound Problems - Panasonic Soundbar
Hi Paul365,
For Sound issues go to Settings > Audio & Video - try setting Dolby Audio to always convert. You can also try different settings such as follow content or disabled
 If you are using a sound bar try connecting the 360 to a TV HDMI port without ARC.
If you are using  fibre optic straight from the 360 to your sound bar, set Dolby to Follow Content.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
Molly_G
  • 775
  • 39
  • 94
Hey @Paul365,
Welcome to the forums and many thanks for your post! Sorry to hear of your syncing issues when trying to watch TV.
Has the advice given by newapollo helped resolve this?
Let us know if you need any further assistance 🙂
Kind regards,
Molly_G
