on 31-05-2022 16:34
on 31-05-2022 17:46
Hi @ceva156
If your 360 keeps rebooting then you need to phone it in as a fault.
You should call 150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults)
When calling Faults you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
31-05-2022 18:30 - edited 31-05-2022 18:32
Whilst newapollo is correct to say this is a box fault regardless of model, I'd mention one small thing in addition..
@ceva156 wrote:Over the past few days, my v6 box with virgin 360
There's no such thing as a V6 with 360. The two descriptions refer to the software, and TiVo/V6 is not TV360.
You used to have a V6 and have now converted it into a TV360. At that point it stopped being a V6, that refers (among other things) to the TiVo software that your box doesn't run anymore.
on 04-06-2022 12:48
Hi @ceva156,
A warm welcome to our Community Forums and thanks for your post.
I am sorry to hear you've been having some issue with your service.
Unfortunately, I was unable to locate your info using your Forum profile so haven't been able to check our systems for any faults.
Did you manage to speak with our team or do you still require our help?
