on 01-11-2022 11:08
Upraded my V6 box to 360 and i'm trying to use this in another room. Main room now has 360 box (working fine). Replaced old Tivo box which was in the second room with my old V6 box.
Now after booting up the upgraded V6 box. It asked to connect remote. I have new 360 remote (which connected while upgrading) but this will not connect after holding down 'TV' and '0' for 10 seconds.
on 01-11-2022 11:13
@Manimal007 wrote:Hi,
Hi @Manimal007
It's possible that the second (older) V6 hasn't upgraded to 360 yet.
Have you tried using the older V6 remote first and clicked on the "Upgrade to Virgin 360 now" app on the Home screen or from within All Apps?
upgrade to 360
on 01-11-2022 11:40
Thanks for your reply.
Clicked on the upgrade option in home screen. Then asked me to pull the tab on remote. The remote connected. Then the boxed turned off. This is when I removed the V6 box and replaced with 360 box.
Gone to swap over my old Tivo box in second room with the V6 box. Remote won't connect.
on 01-11-2022 16:18
Hi Manimal007,
Did your your V6 box complete the upgrade to 360, when you swapped it with the TiVo did it start up correctly and is it working except for the remote not pairing. This need's to be the remote you used when you did the upgrade because you can't pair 2 remotes to the 360.
Try doing a factory reset of the remote by pressing and holding the TV and Rewind button for 10 seconds, and then try pressing TV and 0 button for 10 seconds to repair.
on 01-11-2022 16:24
Box starts up. Goes to select language screen. Then a short while after shows a screen about how to connect remote.
I've tried resetting remote. I've tried resetting the old remote. None of the remotes will connect.
on 01-11-2022 16:45
If it's stuck on the connect the remote by pressing OK screen have you tried pressing the red button on the old V6 remote.
You could also try taking the batteries out of the new 360 remote to reset it.
