UHD for Sky sports and TNT
mda99das
Up to speed
I have UHD for Sky cinema but just realised not for TNT or Sky sports.
Does TNT have a UHD option?
What are the typical charges for UHD sports both sky sports and TNT?
Many thanks
4 REPLIES 4
1701-e
Fibre optic
If you have TNT sports already then uhd is already included on 531.   You'd be best calling re sky sports uhd as it may depend on what package you are on to get an accurate quote
nodrogd
Sky charges additional fees for UHD sports channels, just as it does for HD..
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
mda99das
Up to speed
Don't I know it. Awful speeds with sky and rubbish service.
Roger_Gooner
The upgrade from Sky Sports HD to UHD used to be £7pm, note that if you only had SD you'd have to also pay for the upgrade to HD.
If you don't have a bundle which includes TNT Sports you will have to add TNT Sports as an optional extra and pay the additional £18pm to watch it.
Note: My username is Roger_Gooner and not Alessandro Volta
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
